Feature Label MinScale Issue
4768
10
04-24-2017 02:19 PM
LloydBronn
I'm trying to have my feature layer labels show up at a certain zoom level. I can set maxScale and get results, but minScale doesn't work.
var labelColor = new Color("#00F");
          var font = new Font();
          font.setFamily("arial");
          font.setSize("10pt");
          var textSymbol = new TextSymbol();
        textSymbol.setFont(font);
          var basin = "{Name}";
        var json = {
          "labelExpressionInfo": {"value": basin + " Basin"},
            "minScale":3
        var labelClass = new LabelClass(json);
        labelClass.symbol = textSymbol;
        waterbasins.setLabelingInfo([ labelClass ]);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Lloyd,
   Using this sample you have to zoom in three levels before the label will show:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>Labeling features client-side</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
   <script src="https://js.arcgis.com/3.20/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/geometry/Extent",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/TextSymbol",
        "esri/renderers/SimpleRenderer",
        "esri/layers/LabelClass",
        "esri/Color",
        "dojo/domReady!"
      ], function(Map, Extent, FeatureLayer,
                  SimpleLineSymbol, SimpleFillSymbol,
                  TextSymbol, SimpleRenderer, LabelClass, Color)
        // load the map centered on the United States
        var bbox = new Extent({"xmin": -1940058, "ymin": -814715, "xmax": 1683105, "ymax": 1446096, "spatialReference": {"wkid": 102003}});
        //create the map and set the extent, making sure to "showLabels"
        map = new Map("map", {
          extent: bbox,
          showLabels : true //very important that this must be set to true!
        // create a renderer for the states layer to override default symbology
        var statesColor = new Color("#666");
        var statesLine = new SimpleLineSymbol("solid", statesColor, 1.5);
        var statesSymbol = new SimpleFillSymbol("solid", statesLine, null);
        var statesRenderer = new SimpleRenderer(statesSymbol);
        // create the feature layer to render and label
        var statesUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3";
        var states = new FeatureLayer(statesUrl, {
          outFields: ["*"]
        states.setRenderer(statesRenderer);
        // create a text symbol to define the style of labels
        var statesLabel = new TextSymbol().setColor(statesColor);
        statesLabel.font.setSize("14pt");
        statesLabel.font.setFamily("arial");
        //this is the very least of what should be set within the JSON
        var json = {
          "labelExpressionInfo": {"value": "{STATE_NAME}"},
          "minScale": 5000000
        //create instance of LabelClass (note: multiple LabelClasses can be passed in as an array)
        labelClass.symbol = statesLabel; // symbol also can be set in LabelClass' json
        states.setLabelingInfo([ labelClass ]);
        map.addLayer(states);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
Lloyd,
   Zoom Level and Zoom Scale are two different animals a map may have zoom levels like 1 through 21 where valid zoom scale could be 500 through 300,000. So a minScale of 3 is a very unlikely value.
LloydBronn
OK. I tried setting the minScale at various points between 500 to 300,000 and the labels aren't showing up at any zoom level.
Lloyd,
   Hmm. Normally a label expression looks like this:
"labelExpressionInfo": {"value": "{SomeFieldName}"},
LloydBronn
Should I even be setting the minScale under the json variable after the label expression? I've tried setting it as labelClass.minScale = 7999; which is zoom level 4 according to this example. The labels still aren't showing up. Do I have to have a maxScale in addition to minScale?
       var json = {
          //labelClass.maxScale =;
Lloyd,
   Have you tried not using either min or max scale just to test if your using label class correctly?
LloydBronn
Yes, the labels show up fine without scale settings. The only thing that has worked is when I set maxScale to 3 or 4. The labels disappear at those zoom levels. That shouldn't work based on what you said before.
Lloyd,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "esri/Color",
        "dojo/domReady!"
          extent: bbox,
          outFields: ["*"]
        var json = {
          "minScale": 5000000
    </script>
  </head>
  <body>
  </body>
</html>
LloydBronn
Still no labels at any zoom level if I set a minScale.
The sample I provided works fine for me did you test it?
