How I can Add a link in Attribute Inspector Editor for the Editor Widget?
3028
04-21-2017 04:23 PM
DairisTapanes_Rios
  1. I'm using Editor Widget with Template Picker. I need to add a link to open a dialog box to do more action in the attribute editor. Please see the attach image.I have tried
    var link = domConstruct.create("a", {
    "class": "action",
    "id": "statsLink",
    "innerHTML": "Attach Documents", //text that appears in the popup for the link
    "href": "javascript: void(0);"
    }, query(".actionList", map.infoWindow.domNode)[0]);
    //when the link is clicked register a function that will run
    on(link, "click", showDialog);
but doesn't work,
I'm using Editor Widget as in this sample (Edit rivers and waterbodies ) I'm wondering if is it possible to add the link as I want ?
thanks in advance !
RobertScheitlin__GISP
Dairis,
   Here is how you would do that for the edit widgets attributes inspector:
          "class": "atiNavButtons",
          "id": "statsLink",
        }, query(".atiButtons", map.infoWindow.domNode)[0]);
Dairis,
          "id": "statsLink",
DairisTapanes_Rios
Thank you so much !
