problems with pulldata()
1916
04-05-2017 03:54 AM
LeonhardStöckle
Hey there,
I am new to Survey123 and was going through the tutorials which are in the Survey123 connect app.
The tutorial XLSForm: Enabling CSV Data into your Survey did not work as intended. I coul not get the data from the second csv-file to show up in my survey.
After some research I also found the blog about the pulldata-function but I could not get it right with the information from there either. The downloadable fish-example worked just fine.
Below I attached my files with which I tried to get the tutorial right.
It would be great if anyone could tell me where i went wrong and how to fix my problem.
Thanks in advance
Leo Stoeckle
BrentKinal1
You have your info file saved as info.xlsx, it needs to be saved as a info.csv.
BrentKinal1
LeonhardStöckle
Such a simple mistake!
Thank you very much!
