Import symbology from layer - arcpy
1092
03-21-2017 07:55 AM
martinaraffellini
Hello!
I am trying to update the symbology of a raste layer using an existing layer file with 2 different functions:
 - update layer
- apply symbology from layer
The same function works with shapefiles, though.
Nothing happens, still the code runs till the end with no error message, which makes it pretty difficult to find the error.
data = arcpy.mapping.Layer(raster)             # raster path defined above
arcpy.mapping.AddLayer(df, depth_data)    # data frame defined above
srcLay = workDir + "Symbology.lyr"    # working directory defined above
srcLayObj = arcpy.mapping.Layer(srcLay)
# this function:
arcpy.mapping.UpdateLayer(df, data, srcLayObj, True)
#  or alternatively:
# arcpy.ApplySymbologyFromLayer_management (data, srcLayObj)
Do you know what a reason could be?
Thank you
Tags (1)
RebeccaStrauch__GISP
This is a duplicate of https://community.esri.com/thread/192108-import-symbology-from-layer-arcpy    Looks like geonet hiccup'd.  Please delete one one of the threads.
martinaraffellini
i did not realize, thank you! i cannot delete it, though. how to?
