Python string replace in a label
5865
03-20-2017 12:15 PM
TimFerguson
I am trying to replace an ampersand with & in a label expression in ArcGIS Desktop 10.4.1
my current code is along these lines:
define FindLable([customer]):
    return replace([customer], '&', '&')
For some reason this throws the following error: "Global name replace is not defined."
What is the correct format for this python code?
I have also tried str.replace and Replace and string.replace.
Thank you,
James
Tags (3)
MatthewDobson
James, try:
def FindLabel ( [Status] ):
 return [Status].replace('&', '&')
TimFerguson
For the record: I am actually using define FindLabel spelled correctly.
MatthewDobson
James, try:
TimFerguson
That was it. Thank you Mathew.
