Display an array with one element per line
2431
03-14-2017 12:54 PM
StahlyEngineering
In a custom widget I want to display the contents of an output array one element per line. Currently the output in the widget's panel is:
RESULTS: 21N29W160,21N29W210
this is the js line that passes the array:
this.Quart.innerHTML = 'RESULTS: '+Quarter;
this is the html line:
<div data-dojo-attach-point="Quart"></div>
eventually each output line will be a link using a specific element of Quarter for the path and name.
Thanks in advance!
ThomasSolow
My advice would be to use an HTML list, like this:
let htmlString = Quarter.reduce((accum, current) => accum += `<li>${current}</li>`, "<ul>");
htmlString += "</ul>"
this.Quart.innerHTML = 'RESULTS: '+htmlString;
For older versions of JS you could do:
var htmlString = Quarter.reduce(function(accum, current){ accum += "<li>"+current+"</li>"}, "<ul>");
htmlString += "</ul>";
You can style the list separately to your liking.
RobertScheitlin__GISP
Stahly,
  Then you need to loop through the Quarter array using dojo array or a simple for loop. and add a "<br>" to the end of each line of text before you add it to the innerHTML.
ThomasSolow
Just be advised that your targeted browsers would have to support ES6 arrow functions and array.reduce to use Thomas's code.
