LayerList 4.x hide layer
7049
6
03-13-2017 01:44 PM
jamesa
I added GraphicLayer to the LayerList Widget sameple and get "Untitled layer."  I wonder is there a ways to hide "Untitled layer" or hide MapImageLayer.    See code below.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>LayerList widget - 4.3</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.3/"></script>
<script>
require([
"esri/views/SceneView", "esri/layers/GraphicsLayer",
"esri/widgets/LayerList",
"esri/WebScene",
"dojo/domReady!"
], function(
SceneView, GraphicsLayer, LayerList, WebScene
var scene = new WebScene({
portalItem: { // autocasts as new PortalItem()
var view = new SceneView({
container: "viewDiv",
map: scene
var parcelGL;
parcelGL = new GraphicsLayer();
scene.add(parcelGL);
view.then(function() {
var layerList = new LayerList({
view: view
// Add widget to the top right corner of the view
view.ui.add(layerList, "top-right");
</script>
</head>
Thank you.
MattDriscoll
Set the listMode on the layer to "hide". See the link below
Layer | API Reference | ArcGIS API for JavaScript 4.3
RobertScheitlin__GISP
James,
   If you add a "title" property to your parcelGL layer then it would not show as Untitled layer.
KenBuja
MVP Esteemed Contributor
You'd have to use the operationalItems property to the collection of layers you want to include
jamesa
Can you show me how do you add that to the code?
I really appreciated that.
Thank you.
JimNoel
I find that I have to add some code to prevent graphics layers from being added to operationalItems:
layerList.operationalItems.on("before-add", function(event){
  if (event.item.layer.type == "graphics") {
    event.preventDefault();
Whenever layerList tries to add a graphics layer to the list, this cancels that operation.  A bit of a hack, hopefully ESRI will come up with a better way of dealing with this!
MattDriscoll
JimNoel
Ah, that's a much better way.  Thank you!  I wouldn't have thought of looking under Layer properties rather than LayerList for that.
