Error: <circle> attribute cx: Expected length, “NaN”
12619
03-12-2017 11:49 PM
AdemKurtipek
Hi all,
Note: I've asked this question here also. But I need urgent help. Any help would be greatly appreciated.
I'm using Arcgis JSAPI 4.3 to develop an application. I'm trying to display some public events on map using a public API provided an events website.
I had XMLHttpRequest response as Json data that includes events latitude and longitude information of many events.
But I'm getting this error in console; MapView.js:379 Error: attribute cx: Expected length, "NaN".
****Error screenshot ****
Error screenshot
When I drag map, error count is increasing more and more.
And marker is always displaying at top left corner as seen below.
Marker(s) always at the top left corner!
var latitude = [];
var longitude = [];
eventIO.request.onreadystatechange = function () {
    if (this.readyState === 4) {
      listItems = JSON.parse(this.responseText);
      data = listItems.recs;
      for (var j=0; j < data.length; j++) {
        latitude.push(data[j].venue.lat);
        longitude.push(data[j].venue.lng);
  require([
    "esri/Map",
    "esri/PopupTemplate",
    "esri/views/MapView",
    "esri/Graphic",
    "esri/geometry/Point",
    "esri/geometry/Multipoint",
    "esri/geometry/Polyline",
    "esri/geometry/Polygon",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/layers/FeatureLayer",
    "dojo/domReady!"
  ], function(
    Map, PopupTemplate, MapView,
    Graphic, Point, Multipoint, Polyline, Polygon,
    SimpleMarkerSymbol, FeatureLayer
    var map = new Map({
      basemap: "hybrid"
    var view = new MapView({
      center: [30, 40],
      container: "viewDiv",
      map: map,
      zoom: 6
    var myPoints = {"points": [[longitude, latitude]]};
    var multipoint = new Multipoint(myPoints);
    var markerSymbol = new SimpleMarkerSymbol({
      color: [226, 119, 40],
      outline: {
        color: [255, 255, 255],
        width: 2
    var pointGraphic = new Graphic({
      geometry: multipoint,
      symbol: markerSymbol
    view.then(function() {
      view.graphics.add(pointGraphic);
Console log screenshot of "multipoint"
AdemKurtipek
I solved it by converting strings to numbers in array.
AdemKurtipek
