Adding/deleting fields in ArcMap 10.3.1
2255
7
03-07-2017 07:05 AM
CCGISCOOP
I am cleaning up an attribute table in Advanced Desktop ArcMap version 10.3.1. It is in an SDE database, registered, versioned, etc. I disconnected all other users and attempted to both delete a field and add a field. I kept receiving two different error messages.  One said there were locks on the data - even after I disconnected everyone - and the other said I didn't have permission to perform the operation even though I created the data and have full edit priviledges. (SELECT, INSERT, UPDATE, DELETE). Can someone illuminate me to what I am missing? I searched the desktop help but did not find any useful information to trouble shoot my issue.
TIA.
Cathy
JoeBorgione
Who owns sde.default?  You or dbo, or sde?  That may be conflict.  Something I've taken quite a liking to is exporting a featureclass to an xml workspace, using xml notepad to make changes and then importing it back in. Admittedly, that may be overkill for your situation, but it's a viable option especially when creating feature classes based on an existing schema that isn't just what you want.
CCGISCOOP
Hi Joe,
SDE is the owner of default. Should that matter, since we have a versioned database?
JoeBorgione
I just created a test feature class, registered it as versioned, and then deleted a field with no problem.  I'm not sure what's going on; you mentioned that you are the owner, so I think we've sidestepped Robert's suggestion. I even deleted a field after switching the version to sde.default.
The one error of locks is pretty common, even after you pop off users;  the best way I've found to get past that  is to stop and restart the service.  The permissions thing is strange though...
CCGISCOOP
Thanks Joe,
Someone else mentioned stopping the service so I will give that a try. It has been a while since I have restarted the service so it might just be feeling cranky today??
JoeBorgione
Yep.  Sometimes you need to burp the baby....
RobertScheitlin__GISP
Cathy,
  Is the user you are connecting with the owner of the data? That is the usual issue.
CCGISCOOP
Thank you for the response Robert. SDE is the owner of the default version. And that is the version of the data I have in my map. I tried changing it to my version but the result was the same. Same errors.
