Calculate Field in Modelbuilder
2548
03-07-2017 12:29 PM
TimWitt2
Hey everybody,
I have a question about Calculate field in Model builder. My case is the following:
I want the user to choose a field that will be calculated and then I want them to choose another field that will be used to calculate said field. It is kinda hard to explain so I have attached a screenshot.
Tim
ChrisDonohue__GISP
Here's an older blog post that may be of help.  I suspect there are some minor changes in the last several years that may need some adjusting, but at least it will provide some ideas.
Generating a choice list from a field | ArcGIS Blog
Also, I'm not sure if this would be of use, but I'll toss it out there as conceptually it matches a possible solution:
ArcGIS Help (10.2, 10.2.1, and 10.2.2) - Using Feedback in Iteration
Chris Donohue, GISP
TimWitt2
Thanks Chris, I'll check it out.
