Use Feature Layer Attribute as GP Service Input
7025
29
03-06-2017 11:15 AM
LloydBronn
I'm trying to click on a country layer and use the country name as input for a GP tool. I've done this with XY inputs from map clicks, but I'm having a lot of trouble getting the attribute from a feature. Do I need a query task? Here is my code snippet. When I add content to the infoWindow, it displays "Country: ${NAME}" so it's not pulling that attribute from the feature layer correctly.
var country = {};
var countriesLayer = new FeatureLayer("http://<ourserver>/arcgis/rest/services/Countries_Outline/MapServer/1");
          map.addLayer(countriesLayer);
          var content = "<b>Country</b>: ${NAME}";
          map.on("click", function(evt){
          map.graphics.clear();
          var graphic = new Graphic(evt.mapPoint);
          map.graphics.add(graphic);
          map.infoWindow.setFeatures([graphic]);
            map.infoWindow.resize(200,200);
          map.infoWindow.setContent(content);
          map.infoWindow.show(evt.mapPoint)
            map.infoWindow.setTitle("Forecast Reports");
            var today = new Date();
            var todayISO = today.toISOString().slice(0,10).replace(/-/g,"");
            var link = domConstruct.create("a",{
                "class": "action",
                "id": "reportLink",
                "innerHTML": "Forecast Report", //text that appears in the popup for the link
                "href": "javascript: void(0);"
              }, query(".actionList", map.infoWindow.domNode)[0]);
          on(link, "click", function(){
            domAttr.set(dom.byId("reportLink"), "innerHTML", "Generating Report...");
            window.gp_chart = new Geoprocessor("http://<ourserver>/arcgis/rest/services/Generate_Forecast_Report/GPServer/CreateReport");
               var country = window.map.infoWindow.getSelectedFeature();
              var taskParams = {
                "Country":country
              //window.gp_chart.execute(taskParams,gpChartResultAvailable,gpChartFailure);
                 window.gp_chart.execute(taskParams);
LloydBronn
Finally figured out a solution:
map.on("click", function uponClick(evt){
            identifyParams.geometry = evt.mapPoint;
            identifyParams.mapExtent = map.extent;
            identifyTask.execute(identifyParams, function(result) {
                for(var i = 0; i<result.length; i++){
                    country = result[i].feature.attributes["NAME"];
               var infoTemplate = new InfoTemplate();
                  map.infoWindow.setTitle(country);
                  map.infoWindow.show(evt.mapPoint);
                          map.getInfoWindowAnchor(evt.mapPoint));
                "class": "action",
                "id": "reportLink",
                "innerHTML": "Generate Report",
                 map.infoWindow.setContent(link);
RobertScheitlin__GISP
Lloyd,
   You have the selected feature so you just have to get the attribute fro the selected feature:
var country = window.map.infoWindow.getSelectedFeature().attributes["country"];
LloydBronn
OK. I keep getting this error: "Cannot read property 'Country' of undefined at HTMLAnchorElement.<anonymous>"
What is the line of code that is throwing this error?
LloydBronn
This line. The attribute is called "NAME".
var country = window.map.infoWindow.getSelectedFeature().attributes["NAME"];‍‍
I also added this for the display and it threw the same error:
var country = countriesLayer.attributes["NAME"];
Lloyd,
  So is
defined (i.e. not null).
LloydBronn
Yes, it's defined "country."
Lloyd,
Should return a Graphic object...? Not a string.
LloydBronn
OK, I'm trying to return a string. I need the name of the country I'm clicking on to be passed into the GP tool params.
Lloyd,
  OK, but the
returns a Graphic then you get the attribute you want from that Graphic using Graphic.attributes.NAME or Graphic.attributes["NAME"] to get the actual string values of the NAME attribute.
