SQL Trigger on Insert in ArcSDE Not Showing
1210
03-06-2017 09:07 AM
MeleKoneya
I have created a Trigger in SQL to update a field called asset_id.
It does work, but I can't see the value until after I save the edit in ArcMap and stop editing.     I am also wanting to see the new asset_id value in ArcGIS WebAppbuilder,  but I don't see it until after I exit the app and reopen it.
The Feature Class is versioned as in ArcSDE 10.2.2 on SQL Server 2014.
I do not have the 'Save Edits to Base' option checked.
Why am I not able to see the edits as soon as they are made on an Insert?
CREATE TRIGGER [sde].[trg_insert_asset_id]
ON [sde].[a98]
AFTER INSERT
AS
BEGIN
-- SET NOCOUNT ON added to prevent extra result sets from
-- interfering with SELECT statements.
SET NOCOUNT ON;
-- Insert statements for trigger here
DECLARE @id int
--PRINT @ReturnValue
UPDATE [dbo].[Sequences]
SET next_id = next_id + 1
WHERE sequenceName = 'ASSETID'
SET @id = (SELECT next_id
FROM [dbo].[Sequences]
WHERE sequenceName = 'ASSETID')
UPDATE s
SET Asset_ID = @id
FROM preserve.sde.a98 s, inserted
WHERE s.OBJECTID = inserted.OBJECTID
END
