Please does anyone have an idea how i can resolve this error "Failure to access the DBMS server [[Microsoft][SQL Server Native Client 11.0]Communication link failure]"
3043
5
03-02-2017 01:15 PM
IreneEgbulefu1
I am trying to compress one of my geodatabase on SDE 10.4 but i keep getting this error below. My native client is version 11 and 64 bits and this error is just peculiar to 2 geodatabases out of the 7 geodatabases that I have on my server
ERROR 999999: Error executing function.
Failure to access the DBMS server [[Microsoft][SQL Server Native Client 11.0]Communication link failure] [sde.DEFAULT][STATE_ID = 15]
Underlying DBMS error [HY000:[Microsoft][SQL Server Native Client 11.0]Unspecified error occurred on SQL Server. Connection may have been terminated by the server.] [sde.DEFAULT]
Failed to execute (Compress).
Rebecca Strauch,
gis servers‌, sde connection microsoft sql server 2012‌,
Asrujit_SenGupta
Check the Direct Connect log files and provide us the error here if any..
IreneEgbulefu1
Do you mean the ArcGIS Server logs
Asrujit_SenGupta
No, the sdedc log file will be present in: C:\Users\%your_user_profile%\AppData\Local\Temp
Open it using Notepad and check for error towards the end of the file.
IreneEgbulefu1
CAN'T OPEN INSTANCE: sde:sqlserver.
Spatial Engine Connection Failed (-409).
Cannot Get Access to Instance sde:sqlserver
Asrujit_SenGupta
That doesn't really help much.
This Bug is similar: Bug: Compress operation fails after encountering a corrupt spatial index when a SQL Server 2008 R2 d...
If possible, re-create the Spatial Index for the data in the Geodatabase and check if that helps.
