use claro css for tabbed panel?
2809
10
02-27-2017 01:47 PM
LefterisKoumis
I use the tabcontainer to create tabbed panel, however the visual needs improvement. Are any other options for css in the Web appbuilber or do we need to import other stylesheets. Thank you.
RobertScheitlin__GISP
Lefteris,
   It is called css precedence. If you have a css rule in a stylesheet then the order that the stylesheets are applied means that the css rules will have priority over others. Css specificity also has a large role too. You can override css riles using !important or just specifying a more specific rule.
Lefteris,
   The styling you are seeing is because you are using the jimu TabContainer dijit. If you are not happy with that look then you can manually edit the css or not use the jimu/TabContainer and instead change your code to use the dijit/layout/TabContainer
LefterisKoumis
Thank you Robert. Actually, I am using the  dijit/layout/TabContainer.
<div data-dojo-type="dijit/layout/TabContainer" style="width: 600px; height: 700px;" tabStrip="true">
<div data-dojo-type="dijit/layout/ContentPane" title="General Environmental" data-dojo-props="selected:true">
Strange. Can you right click a tab in your browser and choose inspect element to see what css rules / stylesheets are being applied?
LefterisKoumis
It does indeed using the dijit.layout.tabcontainer
Lefteris,
  So as you look higher in the parent elements and get to the TabContainer if you look to the right side of the developer tools screen it tells you the inheritance of the css rules:
What dojo theme is listed?
LefterisKoumis
It seems to be claro
Lefteris,
   OK but do you see that the dojo-override.css is being used as well. That is likely where the appearance is being altered.
LefterisKoumis
Yes, but why the dojo-override.css is called? How do I prevent it?
Lefteris,
