Map with missing attribute values
1229
02-21-2017 11:39 AM
KhalidAmin
This is my second day with ArcGIS, and I am loving it!
I was trying to create a map using a shape file with administrative boundaries. I wanted to show the attribute 'count' in the map (Map1). Unfortunately, I have data only for few selected locations, and I want to show them in the whole map (Map2). The information on other administrative units are not available (Map3), and I input them as Zero (0). Actually these zeros are missing. If I consider the them as missing, I get only the partial graphs with values in 'count' attribute (Map4 and Map5).
I am not sure how to fix this. I would appreciate if someone can help me in this regard.
Map1 Map1
Map2Map2Map3Map3Map4Map4Map5Map5
MitchHolley1
So, do you want to show the '0' values as well?
KhalidAmin
I don't want to show '0'... I created a map without '0's, and the map becomes partial (showing areas with values only, map5). mitchh300
MitchHolley1
Then what is your goal?  It seems like Map3 is what you're looking for.
AbdullahAnter
Honored Contributor
I think you need to make a definition query :
"Count" <> 0
Displaying a subset of features in a layer—Help | ArcGIS for Desktop
