Snapping Bug when Editing Vertices in Chrome
3366
6
02-15-2017 02:19 AM
JoseSousa
I have found a major issue with the Snapping functionality that spans across all the applications that rely on the ArcGIS JavaScript API e.g. ArcGIS Online, Portal for ArcGIS, Web App Builder, etc. Tested in the JS API 3.19.
The Snapping works well in all browsers when we are drawing an object. However, once the object is created and we decide to edit the vertices, the snapping fails in Chrome. This works well in Firefox and MS Edge. Sometimes we can even notice that the anchor point (displayed as the plus sign) used for the snapping is stuck in one of the vertices. This affects the editing experience as anything I do causes the changed vertex to snap to the anchor point ruining the whole graphic.
Can you please fix this or suggest a workaround? You can easily test this by dragging a polygon feature service to ArcGIS Online, edit the vertices and try to use snapping. I have checked the SnappingManager and there is nothing there that I can use to override this behavior.
Cheers,
Jose
JoseSousa
This bug was marked to be fixed for the 3.21 release but apparently the fix was already included with the JavaScript API 3.20.
Cheers,
Jose
DanPatterson_Retired
You might have better luck notifying esri through your channels since you are an employee.  Also, sometimes when a workaround is found (ie don't use Chrome), they may take a bit longer to get fixed
RobertScheitlin__GISP
This is a known bug. The BUG id is 000102090
now how did you get that, when it didn't show up on support! you must have a magic keyword list
Dan,
    I was just familiar with this one.
JoseSousa
Hi Dan / Robert,
Thanks for your help. I will escalate this appropriately within Esri as this is currently a critical issue for our solutions.
I will keep this post updated.
Cheers,
Jose
JoseSousa
Cheers,
Jose
