Multiple Users on 1 Arcgis Pro project
11223
11
02-13-2017 02:47 PM
TonyHowze
Currently, in our ArcMap workflow, my staff will sometimes have a need to work on getting multiple maps edited for the same report simultaneously.  This usually isn't a problem, aside from users having the same mxd open at once.  This will send off an "Unable to save" document, but give the user a chance to save a copy for any edits they have made, then with a few shouts we can figure out how to resolve.  This works fairly well because of the single mxd workflow.  We have multiple maps for reports, and I can have my staff tackle as a group.
Now with Pro, all the maps/layouts will be bundled together in one .aprx.  We have just tested having multiple users open the same aprx, make changes, save changes.  There is no notification that any other user is accessing the document, nor has saved the document.   It appears, the first user to open and save, has control of the document.  Other users can make changes, save (no error), but the saves will not be stored.  I foresee this is a HUGE problem.  Am I missing something or has ESRI tackled this issue with a very limited scope (only work on your hard drive)?   If I can't get a notification that another user has the same aprx opened, or if not all user's changes can be saved this will be a non-starter for us to move away from ArcMap.  How are we to address this? Is this a bug??  An enhancement request (which is just silly to me)?
Robert_LeClair
Esri Esteemed Contributor
Tony - interesting but in a scary way certainly.  This issue has been seen by the Pro Dev Team and to my knowledge, will be resolved in the ArcGIS Pro 2.0 release.  More to come...
AdrianWelsh
MVP Honored Contributor
Robert, is there an ETA on the Pro 2.0 release?
RebeccaStrauch__GISP
Adrian, per another post I saw today, it should be release prior to around the UC.....subject to change of course.
edit...  Post I'm referring to https://community.esri.com/community/gis/applications/arcgis-pro/blog/2017/03/05/arcgis-pro-roadmap
DanPatterson_Retired
It is the perpetual release cycle... never fails
Robert_LeClair
Adrian - I'm hearing sometime in June but don't know exactly when.  I suspect before UC to give customers time to work with Pro beforehand.  I'm currently working with an early copy of 2.0 and it allows for more than one instance of Pro running on the same machine now - good news!
AdrianWelsh
This is great news! Thanks for testing this and letting us know (hard to contain the excitement!)
erica_poisson
Robert,
Was this ever corrected in 2.2? I've read the release notes but didn't see this specifically called out.
Erica
Erica
TonyHowze
Erica,
This was resolved in 2.0.  You now get a "[Read Only]" notice in the aprx tile bar and a save as dialog if you try to save.
erica_poisson
Thanks Tony. I didn't notice this but will pay attention in the future.
Erica
