Street Intersections (Advanced Street Rule)
988
02-08-2017 07:32 PM
BenjaminSmith_McRobie1
I'm having difficulty modeling exit and entrance ramps of a highway onto a city street. Specifically at 323 N 15th St, Philadelphia, PA 19102. My issue is that I can't find the right combination of rules and settings to the points and segments to create a clean merge. I will provide screen shots of the work I have. Does anyone know any tutorials that will explain these parameters further and in good detail?
by Anonymous User
Not applicable
Ben,
It takes some experimentation to get the merge to look right. You can try selecting the nodes and re-positioning them. You can adjust the street widths at those points.
If you can share your scene file (.CEJ), and the street rule you are using (.CGA), then one of us can check it out.
If you are using the Complete Streets rule, then contact .
Chris
