Deployment Folder Name
1761
02-08-2017 06:48 AM
MarkCederholm
I'm trying to come up with a good way to automate Runtime updates in my application.  I already have a method for updating the application components themselves, as well as installing the new deployment folder.  The problem is cleaning up the current deployment folder:  each version of Runtime expects a particular name for the deployment folder, and so far I haven't been able to find out what that name is via code.  Apart from baking it into the configuration, has anyone found a way to determine the name of the current Runtime deployment folder?
Tags (1)
dotMorten_esri
Esri Notable Contributor
We don't expose that. Currently the folder is always "arcgisruntime" + [version], where version is the first 2 or 3 digits (we drop the 3rd one if it's zero) *.
v100.0.0 would be "arcgisruntime100.0"
v100.0.1 would be "arcgisruntime100.0.1"
v100.1.0 would be "arcgisruntime100.1" etc
You can get the version using th assembly info:
var assembly = System.Reflection.Assembly.GetAssembly(typeof(ArcGISRuntimeEnvironment));
var version = assembly.GetName().Version;
The combine 'Major', 'Minor' and optionally 'Build' properties together to generate the version string.
* Note: This pattern might change at any point.
dotMorten_esri
MarkCederholm
Thanks for the reply; I figured that might be the case.  Currently I'm putting it in the config file, but I was hoping there was a clever way around it.
