Setting a Reverse Proxy Server on Apache
1844
02-07-2017 01:48 AM
LaurentiuIonescu
Hi everyone,
I have ArcGIS Desktop and ArcGIS Server installed on my laptop, witch runs windows 10 and I want to open the ArcGIS Manager window on my public server witch has as OS Ubuntu Server installed. Opening the ArcGIS Manager window on my localhost works great, but I don't seem to find a work around on how to set the reverse proxy server settings on my Apache web server on Ubuntu. I fallowed the instructions posted here: Using a reverse proxy server with ArcGIS Server—ArcGIS Server Administration (Windows) | ArcGIS Ente...
The server url for my localhost is: http://home:6080/arcgis
The name of my domain is mapwizard.eu.
As I understand from the link above, I should write the lines
ProxyPass /arcgis http://gisserver.domain.com:6080/arcgis ProxyPassReverse /arcgis http://gisserver.domain.com:6080/arcgis
on my httpd.conf file but with my personal url, witch should look like this:
ProxyPass /arcgis http://home.mapwizard.eu:6080/arcgis ProxyPassReverse /arcgis http://home.mapwizard.eu:6080/arcgis
But I receive the following error message:  "Internal server error (status code 500)"
If anyone could give some advice, it would be great.
RandallWilliams
Unsure I understand why you would run ArcGIS Server on a laptop and expose it through a reverse proxy, but the issue seems to be that the proxy can't resolve to your laptop's hostname. This is what I get when I go to http://mapwizard.eu/arcgis/rest
Reason: DNS lookup failure for: home.mapwizard.eu
