Graphic Layer array empty but showing geometry
3445
6
01-31-2017 11:52 AM
RachelAlbritton
I need to access the geometry properties of a graphics array so that I can update the associate attribute values, but when I try and view the properties of my graphics layer the Array is empty - but the graphics are shown on the map.
I've tried changing the log statement to not anything until the graphics "load", "update" or 'update-end" but then it doesn't log anything. What happening here?
Note: The relevant code starts on line 42
    // Create the map
    var map = new Map("map", {
      basemap: "topo",
      center: [-111.841947, 40.765530],
      zoom: 15
    //Create Graphics Layer
    var stopsGraphicsLayer = new GraphicsLayer({
       var vehicleLocationGraphicsLayer = new GraphicsLayer({
    var basemap = new ArcGISTiledMapServiceLayer("https://fmags.fm.utah.edu/arcgis/rest/services/mapservices/public_basemap_2014/MapServer");
    map.addLayer(basemap);
    //add graphics layer
    map.addLayer(vehicleLocationGraphicsLayer);
    map.addLayer(stopsGraphicsLayer);
    //Create Toggles
    var vehicleInterval;
    var vehicle = new Switch({
      id: "vehicle", //defines css - and you can not repeat and id
      value: "off",
      "class": "mblSwSquareShape"
    vehicle.placeAt(document.body); // e.g add the switch to body
    vehicle.startup();
    vehicle.on("stateChanged", function(newstate) {
      if (newstate === "on") {
        //Request vehicle locations
        esriVehicleRequest(15).then(function(vehicleResponse) {
               vehicleGraphicFunction(vehicleResponse);
               vehicleLocationGraphicsLayer.show();
               //I've tried "update", 'update-end' as well with no success
               vehicleLocationGraphicsLayer.on("load", function(){
                    console.log(vehicleLocationGraphicsLayer);
               //logs an empty array
               //console.log( vehicleLocationGraphicsLayer);
          vehicleInterval = setInterval(function(){
               //Make an esriRequest
               esriVehicleRequest(15).then(function(vehicleResponse){
                    //Update each graphic in the GL with data from the esriRequest
                    for (graphics = 0; graphics < vehicleLocationGraphicsLayer.graphics.length; graphics++){
                         //update each graphic in the GL with data from the vehicleResponse
                    //vehicleLocationGraphicsLayer.redraw();
               }, 2000);
       else {
        //Stop setInterval
        clearVehicleInterval(vehicleInterval);
        //Clear graphics
        vehicleLocationGraphicsLayer.clear();
        //Hide graphics layer
        vehicleLocationGraphicsLayer.hide();
    function clearVehicleInterval(graphicsLayer) {
      clearInterval(graphicsLayer);
    function esriVehicleRequest(routeID) {
      return new esriRequest({
        url: "http://www.uofubus.com/Services/JSONPRelay.svc/GetMapVehiclePoints",
        content: {
          apikey: "ride1791",
          routeID: routeID
        handleAs: "json",
        callbackParamName: "method"
      }).then(function(data) {
        return data;
    function vehicleGraphicFunction(data) {
       var vehicleObjects = data
       var vehicleGraphic;
       var vehicleAttributes;
          for (i=0; i < vehicleObjects.length; i++ ){
               //Create Symbology
               var vehiclePNG = new PictureMarkerSymbol({
                    url: "http://batholithtest.fm.utah.edu/map.utah.edu/app/resources/images/icons/shuttleicons/nightred.png",
                    height: 30,
                    width: 30
                 //Create Graphic
                 vehicleGraphic = new Graphic(new Point(vehicleObjects[i].Longitude, vehicleObjects[i].Latitude, map.SpatialReference), vehiclePNG, vehicleObjects[i].VehicleID);
                 //add graphics to layer
                 vehicleLocationGraphicsLayer.add(vehicleGraphic);
RobertScheitlin__GISP
Your code should be:
vehicleLocationGraphicsLayer.on("graphic-add", function(){
  console.log(vehicleLocationGraphicsLayer.graphics);
RachelAlbritton
Thanks for the suggestion Robert, but it still doesn't log anything.
It may have to do with where you are adding the on event listener. Currently you have it inside a result handler for a call to the esriRequest. You should really have the
right after you add the vehicleLocationGraphicsLayer to the map.
RachelAlbritton
Thanks Robert. I can get the console.log statement to work prior to the set interval and after the setInterval, but not within the setInterval which is where it would be most helpful so I can troubleshot. Is this not possible?
          console.log(vehicleLocationGraphicsLayer.graphics); //working for the moment
                    for (gl = 0; gl<vehicleLocationGraphicsLayer.graphics; gl++){
                         for (i=0; i < vehicleResponse.length; i++){
                         vehicleLocationGraphicsLayer.graphics[gl].attributes = vehicleResponse[i].VehicleID;
                         //console.log(vehicleLocationGraphicsLayer.graphics[gl].attributes);
                         vehicleLocationGraphicsLayer.graphics[gl].geometry.x = vehicleResponse[i].Longitude;
                         //console.log(vehicleLocationGraphicsLayer.graphics[gl].geometry.x);
                         vehicleLocationGraphicsLayer.graphics[gl].geometry.y = vehicleResponse[i].Latitude;
                         //console.log(vehicleLocationGraphicsLayer.graphics[gl].geometry.y);
               //console.log("Test");
               }, 2000);
       else {
        //Stop setInterval
        //Clear graphics
      console.log ("Post: ", vehicleLocationGraphicsLayer.graphics);
R.,
   So is there an error in the console saying that vehicleLocationGraphicsLayer is undefined or null or what?
There is an issue I see in your code as well with the way you are trying to set attributes and geometry:
should be more like:
vehicleLocationGraphicsLayer.graphics[gl].attributes.VehicleID = vehicleResponse[i].VehicleID;
vehicleLocationGraphicsLayer.graphics[gl].geometry.update(vehicleResponse[i].Latitude, vehicleResponse[i].Longitude);‍‍‍‍‍‍‍‍‍‍‍‍
RachelAlbritton
Thanks for the tip Robert. There is nothing being logged after the for loop.And the log statements outside the for loop are still inconsistent. Sometimes I get info back and sometimes the array is empty even when graphics are present.
