How to create an attribute for a polygon based on raster value?
2347
01-31-2017 10:56 AM
RobertTrotter
Hello, I am guessing this is a simple one, but what I would like to do is overlay a collection of polygons on a raster, and add an attribute to the polygons based on the pixel values within polygon.  I.e. the polygon now includes an attribute describing the maximum/minimum/mean etc pixel value within the polygon.
Thank you
DarrenWiens2
You can use Zonal Statistics as Table and join it back to the original polygons. If it's an integer type, you could also Build Raster Attribute Table of the result of Zonal Statistics, and join that.
JayantaPoddar
RobertTrotter
Hi Jayanta, using the zonal statistics results in a raster, I would like to produce (or retain) the original shapefile, with a new attribute which documents the largest or smallest value within the polygon.  Hoping to find a simple way to do it but perhaps there is not a quick way!  Thanks!
DarrenWiens2
RobertTrotter
That seems to have worked, thank you!
