Storymap Cascade Map Pop-up Issue
1406
01-30-2017 12:39 AM
ElsaVogts
Hi there,
When I publish my Storymap in public mode (http://arcg.is/2hAXKNh ), the first map does not show its layers and relevant pop-up, however all the rest of the maps in the story appear perfectly? In private mode, it shows fine when I preview it. I used the same action to incorporate the maps, but this first one appears to bug out - any ideas why?
Thanks!
OwenGeo
Esri Notable Contributor
Hi Elsa,
Sorry you are having an issue with your Cascade story. It looks like you have a KML layer in that map that is not shared publicly. Can you try sharing that and then checking again?
Owen
Owen Evans
OwenGeo
Hi Elsa,
Owen
Owen Evans
ElsaVogts
Thanks Owen, problem solved!
I had another question however - when I share the Storymap link after sharing it publicly, it prompts the user to log in or create an account to view the Storymap? Is there a reason for this, or is it a setting I can change? Not ideal to have everyone who wants to view my Storymap to have to create an account...
Elsa
OwenGeo
Elsa,
Hmm, I just accessed your entire story using the link you provided in your original message without being asked to log in or create an account. When you share a story and all its components publicly others do not need to have/create an account to see it.
Can you provide a little more detail about the situation you are seeing?
Owen
Owen Evans
ElsaVogts
Hi Owen,
Strange...that bug seems to have fixed itself! Thanks for the help!
Elsa
