Customize layout search widget
1908
01-27-2017 03:20 AM
GilbertoMatos
Hello!
I need to make customizations to the layout of the search widget, but I'm not finding the correct location and template. Any suggestion? I checked the path "... \ jimu.js \ dijit \ templates", but I did not succeed. When debugging the code through chrome, I checked that the following structure is mounted, but even then, I did not find the template.
Any help will be helpful.
Thank you!
Gilberto.
KrishV
You can find Search widget as shown in below screenshot:
Regards,
Krish
GilbertoMatos
Hello Friend!
Thanks for the help, but what I need to know is the dijit template. This html file contains a basic search structure, but what I need is a point where you find a structure with the search field, button, and so on.
Thank you!
Hug,
Gilberto.
RobertScheitlin__GISP
The search Fujitsu is part of the JS API so you will not find that in the WAB source code. You will only be able to modify by CSS.
