Copy a line field to a point attribute table
1188
01-26-2017 04:57 AM
AYGÜNALBAYRAK
I wanna try to copy a line's field to other point attribute table. The point has intersection with the line. the line's layer field should be shown in the point's infrastructure type field. I showed the line and the point image with an attachment.
JayantaPoddar
Try Spatial Join—Help | ArcGIS for Desktop .
Choose the appropriate fields to join in FIELD_MAPPING parameter.
Think Location
AbdullahAnter
Honored Contributor
Jayanta Poddar  suggest is a perfect solution , that is my first one in this propose.
But in the easy task for one or two features only , I suggest to use Attribute Transfer Tool.
that if you have null fields to fill.  About spatial adjustment attribute transfer—Help | ArcGIS Desktop
