Print Widget Question
1725
01-23-2017 11:20 AM
TinaKwitkoski
Hello
I have a client using a JS webmap we created and they want to print 24"x36" size plots from the print widget. there does not seem to be anything larger than 11x17 size. Is it possible to print larger maps? if so can you let me know how to go about this?
Tags (1)
RobertScheitlin__GISP
Tina,
   The process involves setting up a custom print service on ArcGIS Server and defining your custom print templates that this service will use to print (i.e. print templates that are larger than 11 x 17).
Here is the help do with specific links for doing this:
Printing in web applications—Documentation (10.5) | ArcGIS Enterprise
DerekLaw
Esri Esteemed Contributor
Hi Tina,
This is an older video, but the concepts are still the same in terms of how to publish your own print service in ArcGIS Server, ArcGIS for Server 10.1: PrintingTools Service Tutorial
Hope this helps,
