How to query a non-ArcGIS database from WAB?
13283
41
01-12-2017 02:35 PM
WilliamMiller4
I need to send information from my WAB app to a non-ArcGIS database, run a query and return the results back to my app. From what I see online, using only JavaScript is not a secure idea. It looks like I need an intermediary, which my employer would like to be Visual Basic. If someone has successfully done this, please let me know how I might go about it. Any help is appreciated. Thank you for your time.
William
Drew
You would have to know the database, table name and the credentials to connect to the database.
• Assuming it’s a SQL Server database, its just like connecting to SDE and adding data the same way.
• Add a database connection in ArcCatalog
• In ArcMap just use the add data button and browse to your table.
• Once added got to the table of contents and select the ‘List by Source’ icon to see the able listed.
• Publish to ArcGIS Server
o You might have to register the database with ArcGIS Server
• Navigate to the map services REST endpoint and look for your table.
• You now have a layer you can query using the JSAPI
Drew
RobertScheitlin__GISP
William,
   JS does not have any database access ability like native languages do so you would have to use a web service to query and return json or xml to the JS client. I do this for several of my sites but I am an experinced .Net and JS developer. You can search the web for VB.net RESTfull web service examples as a starting point (the majority you will find will be for C# though).
WilliamMiller4
Hi Robert,
I have a very basic web service. How do I send the search criteria collected from a widget with JavaScript to that web service?
William
William,
  With some code like this:
        var requestHandle = esriRequest({
          url: 'your rest service url',
          content: {
            ppin: ppin,
            f: 'json'
          handleAs: "json",
          timeout: 10000
        },{useProxy: true, usePost: false, disableIdentityLookup: true});
WilliamMiller4
Hi Robert,
I have a couple questions.
If I use XML instead of JSON, is the following format correct?
  content: {
    xmlContent: xmlContent
  handleAs: "xml",
  timeout: 10000
requestHandle.then(requestSucceeded, requestFailed);‍‍‍‍‍‍‍‍‍
If I'm running Web AppBuilder on my desktop, can I still test this functionality?
Thank you for your help.
William
William,
  Assuming that your web service has one input parameter and it is called "xmlContent" then yes. You should be able to put a console statement in the requestSuceeded function to show the results of the request. I not sure the reason you choose xml as the defacto standard now a days is json though.
WilliamMiller4
Hi Robert,
I've been having trouble creating a new web service, so I was trying the one that was used with flexviewer. That web service however is SOAP. I asked the guy who developed it what the input parameter name was and he said it wasn't named.
William
William,
   You will not be able to use a SOAP service, that is why I mention a RESTfull web service was needed.
Drew
As mentioned below, maybe you don't even need a service.
Can you add the 'non-ArcGIS database' as a table in the Map Document (mxd) and publish it?
Once in the service you can just query it like any ArcGIS service.
WilliamMiller4
Hi Drew,
The database I need to connect to has real estate information that is updated regularly. I don't know, but I would guess that adding a table would not work for this situation. Please correct me if I'm wrong. I don't know much about Map Documents.
William
