How to query a non-ArcGIS database from WAB?
15216
41
01-12-2017 02:35 PM
WilliamMiller4
I need to send information from my WAB app to a non-ArcGIS database, run a query and return the results back to my app. From what I see online, using only JavaScript is not a secure idea. It looks like I need an intermediary, which my employer would like to be Visual Basic. If someone has successfully done this, please let me know how I might go about it. Any help is appreciated. Thank you for your time.
William
RobertScheitlin__GISP
William,
   The ASP.net Web API is the easiest route now a days.
WilliamMiller4
Hi Robert,
I would definitely go that route, but I only have access to Visual Studio 2010 where I work. Most of the tutorials/examples require 2012 or newer.
William
Man you are just batting a thousand here.
Try this tutorial then:
How to: Create a Basic WCF Web HTTP Service
WilliamMiller4
Hi Robert,
Thank you. This is similar to an example I found on Code Project. Two questions for clarification:
Both have a console application for using the Rest service. I don't need that. I will include similar code in the Web AppBuilder widget to use the Rest service, correct?
So, for the Rest service created using WCF, I should focus on the IService (interface), the Service (class implementing the interface), the webconfig and, according to the Code Project example, an ASAX, right?
William
Correct
WilliamMiller4
Hi Robert,
I have a JSON that I want to send to my restful web service. I created it using WCF. I have a class in my service with the same structure as the JSON. How do I have the class constructor read the JSON to create the object so I can use the data?
William
William,
   That question has me really scratching my head... With a normal WFS web service you query a DB and create a object and set the return type of the service to be json.
Drew
I think he is wanting to send JSON data to the web services.
In this case the service sees it as a string and then you can convert it to your object using JSON.NET
Lots of info on google about this
https://www.google.ca/search?q=.net+Convert+JSON+TO+oBJECT&rlz=1C1CHBF_enCA715CA715&oq=.net+Convert+...
Thanks Andrew a missed that word send.
        var requestHandle = esriRequest({
          url: 'http://your rest service url',
          content: {
            ppin: ppin,
            f: 'json'
          handleAs: "json",
          timeout: 10000
        },{useProxy: true, usePost: false, disableIdentityLookup: true});
        requestHandle.then(lang.hitch(this, function(taxBillJSON){
Where content is what you are trying to send to the service and ppin is the property name of the input parameter.
WilliamMiller4
Hi Robert,
If the main function of my rest service has the following format (in VB.NET):
Function RatioQuery(ByVal p_QueryObject As String) Implements IRatioQueryService.RatioQuery
End Function
Does the following format for the EsriRequest look okay, with ppin set to "p_QueryObject"?
  url: "rest service URL",
  content: {
    ppin: "p_QueryObject",
    neighborhood: this.m_Neighborhood,
    schoolDistrict: this.m_SchoolDistrict,
    useCodeOne: this.m_UseCodeOne
  handleAs: "json",
  timeout: 10000
requestHandle.then(lang.hitch(this, this._requestSucceeded), lang.hitch(this, this._requestFailed));
Do I need to have f: 'json' in the content object?
Thank you.
William
