How to query a non-ArcGIS database from WAB?
15208
41
01-12-2017 02:35 PM
WilliamMiller4
I need to send information from my WAB app to a non-ArcGIS database, run a query and return the results back to my app. From what I see online, using only JavaScript is not a secure idea. It looks like I need an intermediary, which my employer would like to be Visual Basic. If someone has successfully done this, please let me know how I might go about it. Any help is appreciated. Thank you for your time.
William
RobertScheitlin__GISP
William,
  Based on you rest service signature it looks like it is only expecting one input parameter "p_QueryObject" so you input should only contain that.
WilliamMiller4
Hi Robert,
So to pass a JSON as a single parameter, would the following work?
_onSearch: function(){
var queryJson = this._buildQueryJSON();
var requestHandle = esriRequest({
  url: "rest service URL",
  content: {
    ppin: "p_QueryObject",
    queryJson: queryJson
  handleAs: "json",
  timeout: 10000
},{useProxy: true, usePost: false, disableIdentityLookup: true});
requestHandle.then(lang.hitch(this, this._requestSucceeded), lang.hitch(this, this._requestFailed));
_buildQueryJSON: function(){
  var queryJson = {
    neighborhood: this.m_Neighborhood,
    schoolDistrict: this.m_SchoolDistrict,
    useCodeOne: this.m_UseCodeOne
  return queryJson;
William
William,
  It would just be:
content: {
    p_QueryObject: the var that contains the data you are passing
WilliamMiller4
Hi Robert,
To call a rest service function that takes no parameters, would the following code work?
          url: "serviceUrl/functionWithNoInputParameters",
          handleAs: "json",
          timeout: 10000
        requestHandle.then(lang.hitch(this, this._listRequestSucceeded), lang.hitch(this, this._listRequestFailed));
Thank you.
William
Yep that looks good
WilliamMiller4
Hi Drew,
So you think JSON.NET would be better than .NET JavaScriptSerializer?
William
Drew
Either JSON.NET or the JavaScriptSerializer will work fine. I can not say what is better for this specific purpose. They will both work.
WilliamMiller4
Hi Drew,
I asked about JavaScriptSerializer because I was having trouble adding JSON.NET to Visual Studio 2010. It kept telling me to update NuGet before adding JSON.NET, but wouldn't let me update NuGet. That was Friday. Today when I tried, I was prompted that there was an update for NuGet, would I like to install it?
Anyway, so far the main function for my rest service looks as follows (in VB.NET).
Function RatioQuery(ByVal p_QueryObject As String) Implements IRatioQueryService.RatioQuery
  Dim deserializedSearchParameters As SearchParameters
  deserializedSearchParameters = JsonConvert.DeserializeObject(p_QueryObject)
  //p_QueryObject = {neighborhood: "MyNeighborhood", schoolDistrict: "MySchoolDistrict", useCodeOne: "MyUseCodeOne"}
End Function
I have a SearchParameters class with the following basic structure.
Public Class SearchParameters
  Private m_Neighborhood As String
  Private m_SchoolDistrict As String
  Private m_UseCode1 As String
  Public Property Neighborhood As String
    Get
      Return m_Neighborhood
    End Get
    Set(value As String)
      m_Neighborhood = value
    End Set
  End Property
  Public Property SchoolDistrict As String
    Get
      Return m_SchoolDistrict
    End Get
      m_SchoolDistrict = value
    End Set
  End Property
  Public Property UseCode1 As String
    Get
      Return m_UseCode1
    End Get
      m_UseCode1 = value
    End Set
  End Property
End Class
How do I set up the constructor for SearchParameters to get the proper values from the JSON in the p_QueryObject string assigned to their corresponding counterparts in SearchParameters?
Thank you.
William
William,
Here is an example signature of one of my RESTfull web services:
<WebGet(UriTemplate:="/searchPersonalProperty?value={val}&by={by}", ResponseFormat:=WebMessageFormat.Json, BodyStyle:=WebMessageBodyStyle.Bare)>
Public Function SearchPP(Optional ByVal val As String = "", Optional ByVal by As String = "") As ppSearchResults
And the JS code to call it:
  url: 'http://..../searchPersonalProperty',
  content: {
    value: sValue,
    by: byWhich
  handleAs: "json",
  timeout: 10000
  useProxy: false,
  usePost: false,
WilliamMiller4
Hi Robert,
Are you suggesting I use this format so I can avoid having to deserialize a JSON?
William
