Edit Widget - True/False attributes from none-SDE SQL database
1941
01-05-2017 07:53 AM
GertConradie
When publishing a Feature Service that enable editing of True/False (bit) attributes on SQL Server records in a SDE database, one can configure Coded Value Domain that can be used as a dropdown for selection (i.e. yes/no, instead of a checkbox).
What to do if I have a none-SDE SQL database? (Text boxes for numbers is being displayed by default for the bit type, that is converted to a Short Integer by the ArcGIS Service/MXD)
I'm at a point where I'm considering creating a custom version of the Edit Widget that I can configure, but hopefully there is a different option.
Using WAB Developer edition.
Any ideas will be much appreciated!
G
RobertScheitlin__GISP
Gert,
   Hmm. if you are using a FeatureServer service then isn't a versioned geodatabase required?
GertConradie
Hi Robert
No, I'm pretty sure it is not required - in fact we use it to update entities in a none SDE database already. It don't think there is a license problem as well, because one of the ESRI workflows is:
"You want to publish a feature service to ArcGIS Server using data from a single on-premises database or enterprise geodatabase."
GertConradie
What I can add based on past experience - when using SQL server and you have a strict relationships for lookup tables, then the identity insert must be (0,1) on the lookup tables, not the default (1,1). This is a pain to manage - especially if your lookup is also transactional records that can be deleted (The very first transaction record with ID 0 can then be deleted, then your feature service inserts start to fail)  In a previous project we only 'read' the feature service and then saved back via a custom WebAPI service, not the default 'ApplyEdits' on the feature service. (using custom widgets, not the default edit widget)
Gert,
   I primarily use geodatabases so I don't know what to tell you.
