Error 400 (invalid redirect URI) when using OAuth 2.0
6572
12-30-2016 12:27 PM
JesseOsborne1
I've registered a web app in my AGOL org account. It's not a geospatial app, but will be pulling secure data from REST services in AGOL that are only shared with specific individuals . When I registered it, it generated an App ID and I followed the OAuth2.0 examples to try and have the app login on behalf of itself. However, I continue to receive an error: 400 (invalid redirect uri) whenever I try and launch the esriId.getCredential() method using Identity Manager.
______________________________________
Snippet here:
var portalUrl = "https://www.arcgis.com";
var info = new OAuthInfo({
appId: "<removed app id for this question post>",
popup: true
esriId.registerOAuthInfos([info]);
esriId.checkSignInStatus(info.portalUrl + "/sharing").then(
function (){
// User has signed in
displayItems();
).otherwise(
function (){
// User has not signed in
domStyle.set("anonymousPanel", "display", "block");
domStyle.set("personalizedPanel", "display", "none");
on(dom.byId("sign-in"), "click", function (){
// user will be shown the OAuth Sign In page
esriId.getCredential(info.portalUrl + "/sharing", {
oAuthPopupConfirmation: true
).then(function (){
displayItems();
In the esri documentation when it says when registering the app, that a Redirect URI are "valid addresses that users of your app can be redirected to after they successfully log in." Am I not this understanding correctly, but shouldn't this mean that the Redirect URI should be the same as the address of the application? If my application is located at https://this.com, upon a user signing-in wouldn't I want the user to return to just return https://this.com after they've signed in?
TCEQGIS_Team
Jesse, have you added your redirect uri to the list of allowed uri's at the bottom of the Authentication tab on the page where your app is registered?
The uri here has to match the redirect uri in your code. I received an error, that seems to be the same as yours, and it was because I had not added the uri to the list or I had a disagreement between my redirect uri var in my code and the allowed uri's in my list on the app registration page.
