Widgets in sub-menu operations in header controller
3225
11
12-26-2016 10:32 AM
GilbertoMatos
Hello!
I have the following widgets in the header controller, exactly in this order: layers, buffer, print, measure, legend, base maps and about.
I need to modify the header controller widget so that the Buffer, Print and Measure widgets are in a sub-menu called Operations.
How should I proceed? I tried several ways, even put a div with the fixed menu, but there was no way, because I can not open the widgets if it does this way.
Thanks for any help.
Gilberto.
RobertScheitlin__GISP
Gilberto,
   This seems to work:
_resize: function()
    var box = html.getContentBox(this.domNode);
    //by default, we show all elements
    this._showSwitchableElements(['title', 'links', 'subtitle']);
    // this.timeoutHandle = setTimeout(lang.hitch(this, function(){
    //   this._createIconNodes(box);
    // }), 50);
    if(!this.IconNodeCreated){
        this.IconNodeCreated = true
Gilberto,
   What is wrong with making a widget group then?
Widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers | Group Widgets
GilbertoMatos
Hello Robert!
The widget group does not work because the user wants to open 3 submenus (Buffer, Measure and Print), and when clicking on any of them, just open the chosen widget.
Group widgets create a single menu, and it opens all three widgets in one go.
Thank you!
Gilberto
Gilberto,
  In that case you are looking at custom development then. I have never had a need for that type of functionality so I can not guide you there.
GilbertoMatos
No problem Robert!
Thanks for the help anyway.
Thank you!
Gilberto.
GilbertoMatos
Hello!
Robert, I'm customizing the header controller widget to mount the menu and submenus as needed. I have already been able to assemble the structure correctly with all the items. The problem I'm facing, is that after opening one of the widgets, I get the following error (in this case the layers widget):
Error: Tried to register widget with id == widgets_LayerList_Widget_40_panel but that id is still registered
From this, even if I click on any of the other widgets, nothing else happens.
Gilberto.
Gilberto,
  Sounds like you are trying to re-create a widget that has already been created, instead of just opening it. Hard to give advice without seeing what your menu Item code is executing.
GilbertoMatos
Robert, attached follows my custom header controller widget. I replaced the icons, by texts. I put it in a new div menu items.
If you can check and give me some help, thank you.
Hug,
Gilberto.
Gilberto,
   Your mistake is simple you are creating your icons/menus inside a loop for your logos and thus adding the on click event three times to the icons/menus:
Line 47 is a for loop and 62 is inside that loop so it gets called 3 times instead of once.
                    _createIconNodes: function(box)
                         query('.icon-node', this.containerNode).remove();
                         this._closeDropMenu();
                         var i, iconConfig, allIconConfigs = this.getAllConfigs();
                         //by default, the icon is square
                         this.iconWidth = box.h;
                         var ret = this._calcContainerAndEmptyWidth(box);
                         var marginProperty = window.isRTL ? 'marginRight' : 'marginLeft';
                         var containerStyle = {
                              width: ret.containerWidth + 'px'
                         //add some margein to avoid mess layout
                         containerStyle[marginProperty] = (ret.emptyWidth - 5) + 'px';
                         html.setStyle(this.containerNode, containerStyle);
                         this.maxIconCount = Math.floor(ret.containerWidth / this.iconWidth);
                         if (this.maxIconCount >= allIconConfigs.length)
                              this.headerIconCount = allIconConfigs.length;
                              this.createMoreIcon = false;
                         else
                              this.headerIconCount = this.maxIconCount - 1;
                              this.createMoreIcon = true;
                         if (this.createMoreIcon)
                                        label: this.nls.more,
                         var openAtStartNode;
                         for (i = this.headerIconCount - 1; i >= 0; i--)
                              iconConfig = allIconConfigs[i];
                              var node;
                              //INICIO GILBERTO
                              //if (iconConfig.label == "Medir" || iconConfig.label == "Imprimir" || iconConfig.label == "Buffer")
                                   //node = this._createIconNodeSubMenus(iconConfig);
                              //else
                                   node = this._createIconNode(iconConfig);
                              //FIM GILBERTO
                              if (iconConfig.openAtStart)
                                   openAtStartNode = node;
Gilberto,
   I take that back it is more complicated then that. The issue is that the _resize function calls
this._createIconNodes(box); each time the header is resized and the ORIGINAL method removed all the widget icons using:
but because your code is dynamically creating the menu items you are not doing this and the on click event handler is getting added to the same menu node 3 times.
