Widgets in sub-menu operations in header controller
4578
11
12-26-2016 10:32 AM
GilbertoMatos
Hello!
I have the following widgets in the header controller, exactly in this order: layers, buffer, print, measure, legend, base maps and about.
I need to modify the header controller widget so that the Buffer, Print and Measure widgets are in a sub-menu called Operations.
How should I proceed? I tried several ways, even put a div with the fixed menu, but there was no way, because I can not open the widgets if it does this way.
Thanks for any help.
Gilberto.
RobertScheitlin__GISP
Gilberto,
   This seems to work:
_resize: function()
    var box = html.getContentBox(this.domNode);
    //by default, we show all elements
    this._showSwitchableElements(['title', 'links', 'subtitle']);
    // this.timeoutHandle = setTimeout(lang.hitch(this, function(){
    //   this._createIconNodes(box);
    // }), 50);
    if(!this.IconNodeCreated){
        this.IconNodeCreated = true
GilbertoMatos
Robert,
Thank you very much. It really was a simple mistake, as you mentioned. I'm marking the correct answer.
Thank you!
Happy New Year!
Gilberto.
