overlays two Tiled Map Services with Different Spatial References
2079
5
12-21-2016 08:32 PM
lasinh
i use Esri basemap World_Topo_Map (MapServer)
 then overlay my Tiled Map Services;  my Tiled Map Services display incorrect place.
How To overlays two Tiled Map Services with Different Spatial References in ArcGIS API for JavaScript?( two Services cached scale as same; Different Spatial References)??
my code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
<link href="css/main.css" rel="stylesheet" />
<script src="https://js.arcgis.com/3.18/"></script>
<script type="text/javascript">
var map;
require([
"esri/map",
"dojo/ready",
"esri/SpatialReference",
"esri/layers/ArcGISTiledMapServiceLayer",
"dojo/dom",
"dojo/on",
"dojo/_base/array",
"dojo/parser",
"dojo/domReady!"
], function (
Map,
ready,
SpatialReference,
ArcGISTiledMapServiceLayer,
dom,
on,
array,
parser
ready(function () {
parser.parse();
var spatialReference2 = new SpatialReference({ "wkt": 'PROJCS["VN-2000",GEOGCS["GCS_VN_2000",DATUM["D_VN_2000",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",107.75],PARAMETER["Scale_Factor",0.9999],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]],VERTCS["Hon_Dau_1992",VDATUM["Hon_Dau_1992"],PARAMETER["Vertical_Shift",0.0],PARAMETER["Direction",1.0],UNIT["Meter",1.0]]'
map = new Map("mapDiv", {
spatialReference: spatialReference2
var pathGooglemap = "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer";
var tiled = new ArcGISTiledMapServiceLayer("http://stnmt.dongnai.gov.vn:8080/atlasadaptor/rest/services/Bandochuyende/NEN_CAOSU_vn_g/MapServer");
map.addLayers([tiled]);
map.on("Click", function (evt) {
GooglemapLayer = new ArcGISTiledMapServiceLayer(pathGooglemap,
map.addLayer(GooglemapLayer, 0);
</script>
<title></title>
</head>
<body class="claro">
<div id="conttain">
<div id="divmap_data">
<div id="mapDiv">
</div>
</div>
</div>
</body>
</html>
RobertScheitlin__GISP
La Sinh,
   You Can Not use two tiled services that are not in the same WKID.
lasinh
Thank repply, you have any approach for this problem? can use  Dynamic map service overlay Esri basemap World_Topo_Map (MapServer)?
La Sinh,
   Yes you can use ArcGISDynamicMapServiceLayer as that type layer will request ArcGIS Server to reproject the data to match the maps WKID.
lasinh
About speed, ArcGISDynamicMapServiceLayer speed faster or run faster tiled servicesArcGISDynamic?  MapServiceLayer has not load  faster tiled services?
Tiles will always be faster
