Publishing Survey gets hung up
1965
11
12-21-2016 08:53 AM
CarlHolt1
Occasional Contributor III
Trying to republish a survey, no data to get overwritten , but it gets hung up when trying to delete a service item.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Can you try manually deleting the form item, feature layer and folder by logging into ArcGIS Online's website and going to 'My Content'?  You should then be able to republish.
CarlHolt1
Deleted form item and feature layer, but it still get's hung up
JamesTedrick
Can you try to also delete the .iteminfo file in the survey directory? If that does not work, can I ask you to do an attempt while enabling logging (you can enable logging from the settings button on the gallery page; go to the 'Diagnostics' tab).
CarlHolt1
Can you please remind me where the survey directory is?
JamesTedrick
The easiest way to access is to click on the 'folder' button while the survey is being displayed in Survey123Connect.
CarlHolt1
That worked, but I still had to delete the folder on AGOL that contained web maps.
randeegreenwald
I deleted these items and now I no longer have a survey. Luckily I created a copy before doing the deleting. But I still cannot publish my survey!
CarlHolt1
Is the reason the publishing gets hung up because the feature layer has a view of the feature layer, via a stakeholder layer? and/or the feature layer is being used by an AGOL map?
JamesTedrick
Hi Carl,
That should not be an issue, Survey123 Connect can publish over an existing survey that has views. If you're still having problems, it might make sense to open an issue with Esri Technical Support so this behavior can be debugged.
