Publishing Survey gets hung up
3096
11
12-21-2016 08:53 AM
CarlHolt1
Trying to republish a survey, no data to get overwritten , but it gets hung up when trying to delete a service item.
Tags (1)
randeegreenwald
James and Carl. I did speak with technical support and the problem is a bug in the optional "other" field.
So I had to delete the "other" text and then retype it again. This happened to me twice so I applied the same fix and it worked both times.
CarlHolt1
ragreenw_Nursing‌, what do you mean delete "other" text and retype it? In the label field of Survey123 Connect?
