UNC path use with dataSoureUrl
1313
12-20-2016 06:53 AM
andresarias
My Add-in adds a .lyr file to the current map. When my Add-in reads the .lyr file located on my computer it works fine, but when I point to a copy of the same file on a shared network folder with a UNC path there is an error. I am using the regular UNC path format
string dataSoureUrl = @"\\host-name\share-name\path\file.lyr";
Am I doing something wrong?
#dataSourceUrl
arcgispro‌
c sharp‌
map authoring‌
CharlesMacleod
Can you post a complete code snippet and we will attempt to reproduce. Also....this is 1.3? Thanks
andresarias
That's very kind of you Charles. Right after posting this, I realized how foolish the question is and would have deleted it if I could. I was using a very long UNC path and made a mistake typing it.
