Add Legend Widget to Sidebar
3148
12-12-2016 10:32 AM
chuckfrank
I'm using the sidebar example ArcGIS API for JavaScript Sandbox  and I would like to place the legend widget inside of it.  Is this possible? So far I have only been able to place it at a default location.  It would be great if I could place it inside of a div of my choosing.
Chuck
RobertScheitlin__GISP
Sure here is a sample with that:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>View padding - 4.1</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #sidebar {
      z-index: 99;
      position: absolute;
      top: 0;
      right: 0;
      height: 100%;
      background: rgba(0, 0, 0, 0.5);
      width: 320px;
    #text {
      color: white;
      padding: 3%;
    .esri-legend.esri-widget {
      background-color: rgba(255,255,255,0);
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
  <script src="https://js.arcgis.com/4.1/"></script>
  <script>
    require([
      "esri/WebMap",
      "esri/views/MapView",
      "esri/widgets/Legend",
      "dojo/dom",
      "dojo/domReady!"
    ], function(
      WebMap,
      MapView,
      Legend,
      dom
      var webmap = new WebMap({
        portalItem: { // autocasts as new PortalItem()
      // Create the view set the view padding to be 320 px from the right
      var view = new MapView({
        container: "viewDiv",
        map: webmap,
        center: [-74.045459, 40.690083], // Liberty Island, NY, USA
        zoom: 16,
        padding: {
          right: 320 // Same value as the #sidebar width in CSS
      view.then(function() {
          // get the first layer in the collection of operational layers in the WebMap
          // when the resources in the MapView have loaded.
          var featureLayer = webmap.layers.getItemAt(0);
          var legend = new Legend({
            view: view,
            layerInfos: [{
              layer: featureLayer,
              title: "NY Educational Attainment"
          }, "text");
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="sidebar">
      <div id="text">
      </div>
    </div>
  </div>
</body>
</html>
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #sidebar {
      z-index: 99;
      position: absolute;
      top: 0;
      right: 0;
      height: 100%;
      width: 320px;
    #text {
      color: white;
      padding: 3%;
  </style>
  <script>
    require([
      "esri/WebMap",
      "dojo/dom",
      "dojo/domReady!"
    ], function(
      WebMap,
      MapView,
      Legend,
      dom
        map: webmap,
        zoom: 16,
        padding: {
            view: view,
            layerInfos: [{
          }, "text");
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="sidebar">
      <div id="text">
      </div>
    </div>
  </div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
To expand on Robert Scheitlin, GISP‌ reply, in the constructor, you can specify the HTML element where the legend will be placed.
chuckfrank
Thanks Robert.  That's excellent.  I didn't know the name of the html element, "text" in this case, could be used.  Thanks!
