graphics.SetAttributes not picking the input values
1558
12-09-2016 12:08 PM
by Anonymous User
Not applicable
Hi all,
I am using .setAttributes to a graphics in order to add the graphic and attributes to a feature layer. The problem I have is that s .setAttributes does not seem to work with my input values, except when it is hard coded.
projectarea.setAttributes({ "START_DATE": $("#tesr").val(), "FINISH_DATE": "09/09/2019", "Name": "Alex", "PROJECT_ID": "3", "TREE_COUNT": "3", "ACRES": "4" });
For example, This will not :
$("#tesr").val()
This will work:
"22"
This is my form:
 <form>
                    <div class="form-group">
                        <div class="input-group">
                            <span class="input-group-addon">Project ID</span>
                            <input type="text" class="form-control" placeholder="Project ID" id="tesr">
                        </div>
                    </div>
                </form>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Any idea what is wrong with what I am doing?
Tags (1)
RobertScheitlin__GISP
Alex,
   ArcGIS Server is expecting UTC dates which means you have to take "09/09/2019" and convert it to UTC
var msDate = Date.parse("09/09/2019");‍‍‍
by Anonymous User
Not applicable
Correction to that topic,
My problem is for the date values. They apparently don't transfer from Graphics attributes to feature layer. When it is hard coded, it works fine. Not too sure if it is because the START_DATE in feature layer is a date field?
Alex
projectarea.setAttributes({ "START_DATE": "09/09/2019", "FINISH_DATE": "09/09/2019", "Name": $("#tesr").val(), "PROJECT_ID": "3", "TREE_COUNT": "3", "ACRES": "4" });
                    console.log(projectarea);
                    featurelayerProject.applyEdits([projectarea], null, null, function () { console.log("Features updated!"); }, function (error) { console.log("Features not updated! ", error); });
Alex,
