Where to find an example of moving point (FeatureService) using ArcGIS JS
2208
12-08-2016 12:59 PM
BillChappell
I've spent the last couple hours trying to find an example of how to select and move a point without luck. Plenty of examples for lines and polys but not points. I'm using a featureService. Past experience has shown without examples it's very hard or stupid easy.
Any sites or examples?
RickeyFight
Look here:
Default Editor
In this sample you can click on a point then you can drag it to anywhere on the map.
RickeyFight
Look here:
Default Editor
BillChappell
Thank you both, I was looking for a quick simple example and I could not find it in Google. We just needed a simple app to better place points and this will work.
RobertScheitlin__GISP
Bill,
   Any editing sample that you can find that allows for moving line or polygon geometry will work the exact the same for points.
This sample allows you to move the points:
Edit rivers and waterbodies
