1003 error when sending, no solution after troubleshooting
1991
12-07-2016 02:08 PM
Joseph_Kinyon
When submitting a completed survey I get the error 1003 rollback error.
I've checked some of the other past posts such as multiple geopoints, incompletely closed groups and time calculations.
I've removed the time calculation resulting in continued 1003 error.
I have 2 repeats.
I checked all groups and they all appear to be opened and closed completely.
The only oddity I might have is that I have a repeat inside a group, each repeat located inside a different group, however when I removed repeats nested in a group, the problem of 1003 error continued.
I tested if there is If there is no location for the larger survey as a whole if this was the problem, however my second version with a geopoint at the beginning of form still gets a 1003 error.
One of the repeats has a single geopoint question.
There are no geopoint questions anywhere else in the form.
When I tested repeat without geopoint it would allow me to submit Survey.
Survey123 Connect and Survey123 version 1.9.24.
I thought this issue was resolved in 1.6
JamesTedrick
Esri Esteemed Contributor
Hi Joseph,
Can you share the XLS file that's presenting the errors?  It's a little hard to create a test case just from the description- you explained what you think the problem might be, but it might not be the cause.
Joseph_Kinyon
James,
Whoops, wrong file:
Please review this one:
http://www.gisgeek.com/amphibgeorepeat.xlsx
and thank you.
Joe
JamesTedrick
Hi, I'm still not getting the file. You can attach by going into the 'Use advanced editor' mode in the geonet.
Joseph_Kinyon
fixed above, link text was updated, but link was not.
