Draw Toolbar issues when loading dojox/mobile library
672
12-07-2016 11:20 AM
TimothyNyman
We’ve built an application that uses Esri’s draw toolbar to place markup on a map.  However, when we load any of the following dojox/mobile libraries, the behavior of the polyline and polygon drawing becomes unstable for ipad touch device users:
  • dojox/mobile/View
  • dojox/mobile/ScrollableView
  • dojox/mobile/ScrollablePane
We tested the addition of the libraries using the ArcGIS sandbox at this URL:
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=graphics_add
Here are the steps:
  1. Add ANY of the following three lines to the “require”
  • "dojox/mobile/View"
  • "dojox/mobile/ScrollableView"
  • "dojox/mobile/ScrollablePane"
  1. Comment out the following line within the addGraphic() method (this is done so users can draw multiple lines without having to re-select the Polyline button):
  • tb.deactivate();
The behavior we see when using an Ipad device, after making the changes above:
  • Attempting to draw either a polyline or polygon – requires the user to double-tap to end the graphic (and execute the addGraphic method).
  • After double-tapping, the markup continues to try to draw a new polyline or polygon at the point that the initial graphic ended.  Thus double-tapping does not stop the drawing of graphics – but rather begins drawing an unwanted new one.
  • The instability around double-tapping to stop drawing a graphic only becomes an issue when the "dojox/mobile/View" line is added.
The following is the full sandbox code with the changes highlighted in yellow:
<!DOCTYPE html>
<html>
  <head>
    <title>Shapes and Symbols</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
      #info {
        top: 20px;
        color: #444;
        height: auto;
        font-family: arial;
        right: 20px;
        margin: 5px;
        padding: 10px;
        position: absolute;
        width: 115px;
        z-index: 40;
        border: solid 2px #666;
        border-radius: 4px;
        background-color: #fff;
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      button {
        display: block;
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      var map, tb;
      require([
        "esri/map", "esri/toolbars/draw",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
        "esri/graphic",
        "esri/Color", "dojo/dom", "dojo/on", "dojo/domReady!",
        "dojox/mobile/View"
      ], function(
        Map, Draw,
        SimpleMarkerSymbol, SimpleLineSymbol,
        PictureFillSymbol, CartographicLineSymbol,
        Graphic,
        Color, dom, on
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-25.312, 34.307],
          zoom: 3
        map.on("load", initToolbar);
        // markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
        var markerSymbol = new SimpleMarkerSymbol();
        markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
        markerSymbol.setColor(new Color("#00FFFF"));
        // lineSymbol used for freehand polyline, polyline and line.
        var lineSymbol = new CartographicLineSymbol(
          CartographicLineSymbol.STYLE_SOLID,
          new Color([255,0,0]), 10,
          CartographicLineSymbol.CAP_ROUND,
          CartographicLineSymbol.JOIN_MITER, 5
        // fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
        // the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
        var fillSymbol = new PictureFillSymbol(
          "images/mangrove.png",
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color('#000'),
          42
        function initToolbar() {
          tb = new Draw(map);
          tb.on("draw-end", addGraphic);
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            tb.activate(tool);
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          //tb.deactivate();
          map.enableMapNavigation();
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          map.graphics.add(new Graphic(evt.geometry, symbol));
    </script>
  </head>
  <body>
    <div id="info">
      <div>Select a shape then draw on map to add graphic</div>
      <button id="Point">Point</button>
      <button id="Multipoint">Multipoint</button>
      <button id="Line">Line</button>
      <button id="Polyline">Polyline</button>
      <button id="FreehandPolyline">Freehand Polyline</button>
      <button id="Triangle">Triangle</button>
      <button id="Extent">Rectangle</button>
      <button id="Circle">Circle</button>
      <button id="Ellipse">Ellipse</button>
      <button id="Polygon">Polygon</button>
      <button id="FreehandPolygon">Freehand Polygon</button>
    </div>
    <div id="mapDiv"></div>
  </body>
</html>
