Using the Query widget spatial filter always returns "Query failed !", what am I doing wrong?
2766
8
11-28-2016 06:11 AM
ThomasFurcron
I am trying to make a selection of points based on a polygon layer, but each time it is run it only returns the results "Query failed !"
Are there any known limitations that I am missing? Or is anyone else have similar issues?
thanks for any help.
Tom
RobertScheitlin__GISP
Tom,
  What version of WAB are you using? Are you using AGOL WAB or WAB Dev edition? Are there any other details you can provide?
ThomasFurcron
Robert,
I am using AGOL WAB so I think it is the most recent version.
All layers are hosted from ArcGIS server on site not in AGOL.
The polygon is coming from a feature service and the point layer is coming from a map service.
The map is set up in AGOL and it was set up using WAB in AGOL from there.
tom
Thomas,
   Are both layer in the same spatial reference?
ThomasFurcron
Much to my surprise they were not in the same project.  However i have fixed that and recreated the map service, the AGOL map and web app, and i am still getting the same result.
Tom
Thomas,
   Can you check your browsers web console and attach a screenshot of any errors there?
ThomasFurcron
Robert here are the errors showing up.
  Errors from web app
Thomas,
   I looks like you are at the point when you need to call esri tech support.
ThomasFurcron
Thanks for your Robert.
That is what I was afraid of, I will post back here once I have had a chance to contact them.
Thomas
