Uncaught TypeError: this.map.getLayer is not a function
6259
11-25-2016 06:22 AM
RolandoFlorez
Hi, I need some of help
this is my code:
_reportLayerInfo : function () {
   console.warn('reportLayerInfo');
   console.log(this.allLayerInfos);
   var filteredArr = array.filter(this.allLayerInfos, function (item) {
      return item.getSubLayers().length == 0;
   console.warn('filtered layers infos');
   console.log(filteredArr);
   array.forEach(filteredArr,function(layer){
      console.log(lang.hitch(this,this.map.getLayer(layer.id)));
(sorry, I dont known how put a code block)
So, _reportLayerInfo() method is activate when I clic a button, now, when I clic the button, the console shows me that error: Uncaught TypeError: this.map.getLayer is not a function.
As you can see, I used the lang.hitch because I thought that It was the solution.
Thanks a lot.
Drew
Try calling another function in your class;
Dojo Sample: (see processEvent)
require(["dojo/on", "dojo/_base/lang"], function(on, lang){
  var processEvent = function(e){
    this.something = "else";
  on(something, "click", lang.hitch(this, processEvent));
So your code might be something like...
      console.log(lang.hitch(this,getLayer);
getLayer:function()
RobertScheitlin__GISP
Rolando,
   I agree with Andrew that you need to use lang.hitch to keep your result functions in scope. So the main thing is anytime you have a function call after you do some process your results are likely in a different scope and you need to use lang.hitch to keep that function in the same scope as the main code.
