Template Picker - Adding Features: Looking to limit users to only adding 3 points
2123
11-21-2016 02:14 PM
IanPeebles
Hello everyone.  I am working on a new application that has a template picker that works really well.  I am looking to limit the user where they can only add three points to the map and that is it.  Currently, I have it set up where you click on the template picker, you are in constant draw/editing mode.
Looking to set up a loop on clicks and when you hit 3, you will get an alert that says, "you have added 3 points".  Is there a way I can trap the mouse clicks or the number of edits applied?
I am a bit stuck on this...any assistance would greatly be appreciated.  Below is my code block:
// * Editing Code Block *
function initEditing(evt) {
var layers = arrayUtils.map(evt.layers, function(result) {
return result.layer;
// Editor Toolbar
var editToolbar = new Edit(map);
// Draw Toolbar used to Draw Graphic during Editing
var drawToolbar = new Draw(map);
// Template Picker Widget
var templatePicker = new TemplatePicker({
   featureLayers: layers,
   rows: "auto",
   columns: 1,
   grouping: false
}, "templatePickerDiv");
templatePicker.startup();
// Template Picker Widget - Selection Only Add Point
var selectedTemplate;
templatePicker.on("selection-change", function() {
   if( templatePicker.getSelected() ) {
   selectedTemplate = templatePicker.getSelected();
   console.log("Name", selectedTemplate);
   drawToolbar.activate(Draw.POINT);
drawToolbar.on("draw-end", function(evt) {
// Loop Variables
//var count = 0;
//var i = 0;
//drawToolbar.deactivate();
//editToolbar.deactivate();
var newAttributes = lang.mixin({}, selectedTemplate.template.prototype.attributes);
console.log("Attributes", newAttributes);
var newGraphic = new Graphic(evt.geometry, null, newAttributes);
selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
/* -- Code Not working ---- Commented Out --------------------------------------------------------
for(i=0; i<4; i++) {
count = count + 1;
console.log("Ian Count", count);
if(count < 4) {
else
alert(" You have successfully completed 3 edits!");
*/ -- Code Not working ---- Commented Out --------------------------------------------------------
SteveCole
Honored Contributor
featureLayer.ApplyEdits has a callback function so why not increment your counter variable inside that function? It will only increment if the operation is successful so you're sure to have an accurate & current count of added features. I think you can just check its value BEFORE the ApplyEdits method like you kind of have it already.
Steve
SteveCole
Honored Contributor
Steve
IanPeebles
Steve, thank you for your response.  The biggest issue I was was getting the counter to work properly.  It would have helped if I would of taken it out of the function, because I was getting a constant value of 1 each time.  Here is what was done:
1. Set a global variable
var count = 0;
2. Logic for the draw on end:
   // Draw Toolbar on End
         // Comment out line of code below to allow for adding mult
         // Set up Counter for Graphic Added
        count = count + 1;
        console.log("Graphic Count", count);
       if (count <=3) {
         // Add Graphics for Symbol Placement
        map.graphics.add(new Graphic(evt.geometry, symbol));
        // Feature Graphic and Apply Edits
        // Apply Edits
      else
   return count;
This works really well!  For sure, this was a new challenge.
