How can I make my widget appear in page without clicking the icon to launch?
1245
6
11-17-2016 10:49 AM
RolandoFlorez
I need that my widget appear in the page at begin the application, like scale bar, coordinate or search widget.
What is the configuration that I have to do?
Drew
If your manifest.json file you need to set "inPanel": false
Then you need to add it to the applications config under the 'widgetOnScreen' section
RolandoFlorez
Yeah Andrew, but, which "config.json" file?
Drew
Sorry ** CORRECTION **
You need to add it to the applications config.json (widgetOnScreen) file in your stemapp
RolandoFlorez
Like you've said, by hand, I put the widget, but It keeps showing me the icon to launch the widget, not the widget properly.
Sorry for the inconvenience.
Drew
Are you adding the widget to the 'widgetOnScreen' section in the config file?
JordanKing3
Sounds like you actually want to launch a widget from the widget pool when the application starts, not just have an on-screen widget (e.g. Scalebar, Search)?
As long as the widget has been added correctly to the config.json file, within the root folder of the application, and the actual widget exists within the widget folder, you might be able to call:
PanelManager.getInstance().openPanel('widgetid')
You would need to call this somewhere after all the widgets have finished loading and also somewhere where the PanelManager is instantiated and available. Potentially somewhere within the init.js file after the loadResources() function has finished executing. Not sure exactly where, might take some trial and error.
