Null values switch to 0
1419
11-16-2016 08:16 PM
sanabelja
hi ;
im using 10.4 arcgis n windows10 , ihave a csv file with no data in some cells ,,when i joined it to ashape file and then export it to shape file ,all (No data)  switch to 0 ,which is Wrong !!!!
can any one help ? its urgent
DanPatterson_Retired
your fields are numeric I take it... 0 is the nodata value for numeric values in shapefiles.  If you need to retain <null> then you need to save the results in a geodatabase.  Alternately, you must provide a conversion/replacement to represent null.  For example, -999 or some other number that doesn't exist in the data
