Unable to access the esri library in local web server.
722
11-17-2016 01:25 AM
MathanManohar
I had configured IIS in local system and it serving the web pages. I copied the arcgis_js_api in c:\Inetpub\wwwroot
as instructed in ESRI's ArcGIS API for JavaScript.
  1. Open C:\Inetpub\wwwroot\arcgis_js_api\library\4.1\4.1\init.js in a text editor and search for the text[HOSTNAME_AND_PATH_TO_JSAPI], and replace this text with<a href="https://en.wikipedia.org/wiki/Top-level_domain">fqdn.tld</a>/arcgis_js_api/library/4.1/4.1/
I replaced <a href="https://en.wikipedia.org/wiki/Top-level_domain">fqdn.tld</a>/arcgis_js_api/library/4.1/4.1/ with [HOSTNAME_AND_PATH_TO_JSAPI] in C:\inetpub\wwwroot\arcgis_js_api\library\4.1\4.1\init.js.  I suspect here I am doing the mistake in above step.
I took the sample code from
file:///E:/Software/ArcGIS%20API%20for%20JavaScript/arcgis_js_v41_api/arcgis_js_api/library/download... but I unable to see the result.
When I try to access .css/init.js which is hosted in local server, I can browse in browser. I changed the TileLayer URL REST service and it also browse in the browser.
What step I am missing here?
Thanks In Advance.
RobertScheitlin__GISP
Mathan,
   Yes that is where your mistake is. What the instructions are trying to tell you is you replace [HOSTNAME_AND_PATH_TO_JSAPI] with your machines fully qualified domain name.
So for example in my case it would be:
http://gislap183/arcgis_js_api/library/4.1/4.1/ on my development laptop. Where "gislap183" is my machine name.
