vertices move offset when page is scaled with css transform
1331
11-16-2016 09:35 AM
CalvinShi
I have a map on a div, and I scale up the div by 2 using css transform scale(). now my issue is that when i dragging vertices to change the shape of polygon, it is offset from my mouse point. I don't know if there is a way that i can fix it.
an example of my issue would be https://developers.arcgis.com/javascript/3/samples/toolbar_edit/and add transform-origin: top left; transform:scale(2); to mainWindow div.
any advice and suggestions will be greatly appreciated
KenBuja
MVP Esteemed Contributor
This usually happens when the map isn't resized after map is loaded. Search on GeoNet and you'll see many instances of a mouse offset.
Try putting this in your code
 map.on("load", function(){
   map.resize();
