How to add different color and adding InfoTemplate in every route
1364
11-15-2016 07:34 PM
ozaquisba
Would you help me?
What I need :
- when i click radio3 , then it show 2 routes with a different colours and each route have their infoTemplate
This is my Code
        var jalanLayer = new esri.layers.GraphicsLayer({ id: "jalan" });
        map.addLayer(jalanLayer);
        //setup the route parameters
        routeParams = new RouteParameters();
        routeParams.stops = new FeatureSet();
        routeParams.outSpatialReference = {
          "wkid" : 102100
        routeTask.on("solve-complete", showRoute);
        routeTask.on("error", errorHandler);
        //define the symbology used to display the route
        stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15);
        stopSymbol.outline.setWidth(4);
        routeSymbol = new SimpleLineSymbol().setColor(new dojo.Color([0, 0, 255, 0.5])).setWidth(5);
        //Adds a graphic when the user clicks the map. If 2 or more points exist, route is solved.
        function addStop() {
          $("#loader").show();
          var gl = map.getLayer("jalan");
          gl.clear();
          var stop1 = new esri.Graphic(
          new esri.geometry.Point(longSt,  latSt), stopSymbol);
          stop1.attributes = new Object();
          stop1.attributes.Name = "A";
          var stop2 = new esri.Graphic(
          new esri.geometry.Point(longEnd, latEnd ), stopSymbol);
          stop2.attributes = new Object();
          stop2.attributes.Name = "B";
          routeParams.stops.features.push(stop1);
          routeParams.stops.features.push(stop2);
          if (routeParams.stops.features.length >= 2) {
            routeTask.solve(routeParams);
            lastStop = routeParams.stops.features.splice(0, 1)[0];
          map.centerAndZoom(new esri.geometry.Point(longSt,  latSt),12);
        //Adds the solved route to the map as a graphic
        function showRoute(evt) {
          jalanLayer.add(evt.result.routeResults[0].route.setSymbol(routeSymbol));
          $("#loader").hide();
        // Wire UI Events
        $("#radio3").on("click", function() {
            longSt='106.9935517';
            latSt='-6.2337483';
            longEnd='106.994956';
            latEnd='-6.2592437';
          addStop();
            routeSymbol = new SimpleLineSymbol().setColor(new dojo.Color([0, 255, 255, 0.5])).setWidth(5);
            longSt = '106.9705696';
            latSt = '-6.1916444';
            longEnd = '106.9738868';
            latEnd = '-6.219634';
          addStop();
